1
- #1
I have a very basic question. When you bolt through masonry (through bolt), I know that you use a threaded rod with nuts and plate washers at each end of the bolt. Do you also need to specify some adhesive in the hole, like Hilti HIT HY 20? The through bolt detail in the tech note from the BIA doesn't show any. I guess that if you did try to put something in the hole like grout or adhesive, you would foul up the threads of the rod. I have never used a through bolt before, but I want to use one now. Any guidelines on properly detailing a bolt through multi-wythe brick masonry are greatly appreciated.
