thetank8
- Oct 3, 2013
- 6
A spur gear exhibited a broken tooth during a vibration test. The vibration of the overall assembly translated to an unknown input torque on the shaft of this gear which resulted in it impacting its mating gear in both directions. The rotation of the mating gear is ultimately constrained by a non-backdrivable worm.
Material: S45C through-hardened to HRC 40
Module: 0.35mm
# Teeth: 38
Pressure Angle: 20 deg
Profile Shift: None
Mating Gear Material: S45C through-hardned to HRC 55
First, from the photos of the broken tooth below, is it a correct assumption that the failure mode was fatigue breakage at the root of the tooth?
Second, would changing the material to something like a low-carbon alloy steel and carburizing so it is hard on the surface but still ductile at its core improve its performance? Or should I simply try to increase the through-hardness of the S45C gear as much as possible?
Photo:
Cross Section:
Please let me know if there is more information needed. Thanks!
Module: 0.35mm
# Teeth: 38
Profile Shift: None
Photo:
Cross Section:
