Hi rootsxrocks.
Yeah, I was thinking LEDs => DC.
You can get SSRs that are AC(control) AC(output) but they still aren't negative logic.
None of this is a problem if you were building from scratch your own product but, off-the-shelf...
Okay what you need is two SSRs, one to shunt the control signal of the second. Something like:
You set up the control inputs of the the second SSR to be in series with a light bulb. So as hooked up the supply Hot runs thru the lamp to the the second SSR's control input and from the second control input to the neutral. Now just sitting there with the power applied the second SSR is ON its controlled output closed and running whatever.
Now you send your controlling signal to the control input of the first SSR. Whenever your control signal is ON the output of the first SSR is ON (more correctly, closed).
Hook the output of the the first SSR across the input terminals of the second SSR.
The idea here is that when the first is ON the input to the second is shunted or shorted. This would rob the second SSR of its control signal. The lamp is needed because if you shorted the full AC power running the second SSR it would blow something up. (A fuse hopefully)
The lamp will be dim when the first SSR is non-activated and the only current is the 2 or 4mA needed to activate the second SSR. Once the first SSR is activated, shorting the second's control inputs, the lamp will go to full brightness and the second SSR will shut OFF.
Pitfalls. The first SSR will likely need to be a snubberless output type or the current that normally leaks thru the snubber circuitry may be enough to turn OFF the second SSR's control input regardless of the control signals sent into the first SSR.
Keith Cress
Flamin Systems, Inc.-
