Tie New Roof Extension to Existing Truss 1
STrctPono
706
See attached sketch. For retrofitting an existing roof, we are planning on extending out a new rafter (to match existing roof pitch) out from an existing roof truss. I don't know if this is the best detail to accomplish this. Do you guys have any ideas? Thanks!
 https://files.engineering.com/getfile.aspx?folder=1f8360a4-e7e7-4d9f-8b01-45a56a1a00f0&file=SKM_C55821091010200.pdf
kipfoot, these are both great ideas! The first option looks cheaper for materials but may end up being a wash if they have to spend that time cutting out the existing plywood sheathing to slip the splice plate through. I like the second option because it will allow me to keep the bottom sill nailer plate as a continuous member. Thanks!
