Tie Warning
smtb
6
hi
I am analysis a sandwich panel in abaqus.
I have two faces and a core.
The dimension of each faces is 0.30x0.04x0.0015 and the simension of core is 0.30x0.04x0.02
I make a tie constraint between face and core in that side is 0.3x0.04
if you make attention to dimension both region are rectangular and they are same.
when i submit my job i have below warnings:
"For *tie pair (assembly__pickedsurf179-assembly__pickedsurf178), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly__pickedsurf181-assembly__pickedsurf180), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout."
They are two becouse i maked two tie for each of faces with each side of core separate.
after this warning i input 0.0005 in Specify distance for telorance but i have that two warning yet.
please help me for solving my problem.
