vape
- May 22, 2005
- 2
I am designing a retaining wall which is changing from a cantilevered wall to a tieback wall. I have no problem with designing the reinforced concrete wall to span horizontally between the soldier piles, but I need information about two details:
Are there standard details for the connection between the reinforced concrete wall and the soldier piles? I intend to use headed studs to fasten the wall to the piles, but what considerations should be used to detail the reinf. around this connection. Also, is there a standard for the detailing of construction joints in this type of wall. Are the joints to be placed at the centerline of the piles or held off of the piles?
