Tiebeam Analysis 2
eeedesign
17
To all Designers,
Anybody can give information and references how to analyze TieBeams and what are the loads to be considered. Thanks in advance
"Tie beam" can mean a few things. You'll likely need to elaborate. Are we talking about collectors for lateral loads? Grade beams between piles?
Hi! I mean a TieBeam or Ground/Grade Beam. Thanks KootK
I'll assume that we're discussing an interior tie beam rather than a perimeter grade beam. In seismic country, the axial force is usually a percentage of the axial force in the columns being tied.
Epic post. This forum is full of detail oriented individuals. If you want feedback you need to explain your question better. The best threads usually start with a well formulated problem and a list of specific questions.
Are there more rabbits in the mountains or in the winter?
Mike McCann, PE, SE (WA)
Where I'm from, winter.
This post reminds me of when I was asked to do a quick foundation design for an MTO for an estimate. We were going to crib the design from a project on the west coast (high seismic). The foundation design had interior tie beams and I could not figure out what the purpose of these was until I dig some digging and found they were meant to tie everything together in an earthquake. If you don't know what they're for they sure seem confusing at first.
