GeoEnvCv
- Aug 19, 2011
- 2
I am designing a small timber post and lagging wall. The structure is holding back 5.5 ft of sandy silt with groundwater estimated at 2 ft below ground surface behind the wall. Ground surface at the toe of the wall decreases at a 5:1 slope; ground surface behind the wall is flat. I am considering pure cantilever and anchored walls. A major limitation here is that the shoulder of an existing road is located about 12 ft from the wall, limiting the effectiveness of any deadmen/pile anchors that can be installed.
I have run through some calculations myself (dont have any software for this), but I dont do a lot of work with this type of design;I was hoping someone with more experience in the area could give me some kind of sanity check.
Is there a range you might expect for cantilever driven depths here? Would you expect anchors to be installed here (my calculations have them losing about 2/3 of their effectiveness due to the proximity to the wall)? What sizes and spacing might you expect for the posts of the cantilever and anchored design?
Thanks for the help
Thanks for the help
