engineer817
I am designing a section of a house that has a custom truss roof system supported on heavy timber posts that were gravity designed by a timber post and beam company. The owner wants to keep the aesthetics and the design. I ran a quick lateral design only to find it didnt work. I added a two struts and was able to make it work as long as I can achieve some kind of fixity in the bottom of the post to the foundation wall. I realize that the post may have as much as 16% water content and could shrink 4% or more in dimension. What type of connection would be the best solution? I thought of designing a moment bootmade out of steel plated welded to a baseplated designed for moment but realized the shrinkage in the wood will change it's fixity. The post is 7 1/2 by 7 1/2 inches in dimension and 12 feet high.
