Hi Folks,
In one of my projects, I was asked to reduce the depth of a short(10inch high) concrete wall on which 2x12 stud wall is sitting. The depth of the concrete wall was originally matching with the depth of the studs but now the architect wants to decrease the depth with 2 inches, so instead of a 12 inch deep wall now I have 10 inch wall with 2 inch insulation. The stud wall will be partially sitting on the insulation instead of fully sitting on the wall. I just do not like this detail but also I do not have anything against to it structurally.
Do you folks see any problems with this if yes what are your suggestions ? * The stud wall is very lightly loaded.
Thanks !
Thanks !
