Time to compress fluid in cylinder
byxrube
3
I have an application where I need to determine the time needed to compress a gas in a piston cylinder arrangement a given distance (ie. the time for the piston to travel x inches). Would anyone happen to know the methodology and equations used to find this?
iainuts
Using spreadsheet for numerical integration is limited to the maximum number of cells in a columns. A problem such that may need more integration steps than the number of cells in a columns.
you're not done, you've only found a small enough time step to make the errors so small you don't see them any more. Nobody has solved for time yet. Can we end this wild goose chase soon?
"Pumping accounts for 20% of the world’s energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies)
