GB1000
- Oct 31, 2017
- 28
I'm after some experts to assist with Timoshenko. I'm trying to calculate the deflection at the tip due to shear deformation and loading. I've found many formulas showing deflection at tip when the load is at the end, however none where the point load is at 'x'
I know of Pa^2/6EI x (3L-a) which we generally use when designing say steel beams.
However this is for a composite material where we specifically need to be taking into account the shear deformation as well given the low modulus of elasticity. I know timoshenko is the answer but I have no idea.
My only solution was to use an equivalent UDL and use those formulas but wanted something accurate
Any assistance would be great.
