Tire- Road Interaction doubt.
hariharanyahoo
Automotive
IN
I'm running a simulation using ADAMS in which,
I tired to run the vehicle over a gradient of 17 deg.
when I was changing the road friction from 0.5 to 0.4 vehicle was only able to climb upto a certain distance(say 15m).
Gradient is same in both the simulation, so C.G shifting will be same.
torque input is same.
what is the reason?
cgz means?, C.G location is not very high. and yes it is fwd.
Yeah, But theoretically I would like to know how to find the gradeability of the vehicle
your friction does sounds rather low even if it were wet weather this could cause and issue, or amplify any other issues for sure
