dthom0425
- Dec 6, 2018
- 47
Hi all,
I'm curious to hear your thoughts on how the use of MAX (or MIN for that matter) can be interpreted.
Say we have a dimension on a drawing shown as R.125 (radius). No tolerance associated with the dimension other than the default title block of +/- .005 for 3 place dimensions. So as shown, the feature can range from R.120-R.130.
Now, if we add the MAX nomenclature to the dimension such that it reads R.125 MAX, does that actually negate the lower limit? So if I were to be provided with a radius on the actual part of R.005, does that fall within spec because the MAX nomenclature is only specifying an upper limit? Or does the title block still apply regardless of the MAX nomenclature such that we essentially have .125 +.000/-.005?
Interested to hear your thought
Thank you
Thank you
