How do you set up sheet formats with title blocks. What I want to do is two things. Like starting from scratch except I already have an existing title block I want to use with company name and all that.
1. I need to set up the drawings with title blocks on them, a,b,c, and d size.
2. If needed I want to be able to change sheet sizes and the new sheet size has its own title block. So if I start a b-size drawing and decide half way thru detailing that it would fit better on a c-size I can easily change sizes and title blocks.
Thanks!
Thanks!
