  • Congratulations Toost on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
TJI collar tie
Henry94606
Student
May 24, 2021
14
I understand TJI are not made to work with collar.
In typical gable roof I used TJI-9.5" for longer span and cheaper price compared to sawn lumber.
Ceiling joists (red) then run parallelly with TJI and coil strap (green) at ridge beam. So far it has been oked, approved by AHJ a few time.
I read TJI manufacturer documents and they recommended straps/ties (yellow) run in perpendicular direction to TJI. I m sure they have engineer department, etc.
I wonder such recommendations have anything to do with resisting side walls to lean outward, as I m, an architect s understand the most concern regarding gable roof rafters. Or they are there just merely for blocking purpose.
Thank you in advance,
