Structeng_1414
- Aug 4, 2023
- 2
Hi, I am trying to lay out joists for some non-orthogonal walls. These will be top flange hangers to top plates of the bearing walls. My question is, would you lay it out at a similar angle to both walls (parallel to the exterior wall here), or with 90 degrees to at least one wall?
Thinking for constructability it might be easier to have 90 degrees to at least one wall, but I really don't know if it matters. It also will end up at a weird angle to the exterior wall so might have to do a beam across with infill like this?
