nattapong.s
- Jun 10, 2017
- 6
I need some advice regarding the humidity control.
...Outdoor Condition 95 F and 60%RH and Indoor 74 F 50%RH.
Our existing substation & Control Room is located in Tropical Zone (Thailand). My Client is facing the problem the exceeding in Relative Humidity in room cause the panel surface wet.
The system itself is Centralized Single Zone Constant Flow AHU and OA 40% are introduced to mix with RA. From my first investigation, the A/C was designed and selected with a massive margin over the design load in which it merely seem 30 -40% Part Load
I offer many solutions to customer however they accepted only the adding the Duct Heater (preheating coil) to simulate the artificial load in order to let compressor continuously operate. My queries are
1. The Sensor to drive the Duct Heater could be Humidistat or Temp sensor.
2. Is it ok to preheating coil only do we need reheat coil?
Thanks in advance.
Best Regards,
Thanks in advance.
Best Regards,
