This is a question I've been wondering for a long time and am finally going to ask to get to the bottom of this (hopefully). Now, I've mainly done steel buildings with steel framed stair and elevator shafts, so this is the first time I'm having to design concrete stair and elevator shafts.
My questions is, say you have a stair shaft with a 3ft opening on each floor with a concrete beam above to opening, must I design this beam as a coupled beam? I'm choosing to design the shear walls as individual components as opposed to as composite sections (C-shape). In my ETABS model, I was planning on using a pin-pin connected concrete beam above the opening in order to ensure that the model doesn't "couple" the walls.
I have a number of textbooks (5 in total, including ones covering seismic design in concrete) on concrete design and I haven't found any information discussing this issue, other than the design and detailing of coupling beam. But nothing on "when to" or "must I" couple the walls.
I should mention that this building is in a low seismic region in Canada and I'm using "conventional construction" (Rd=1.5, Ro=1.3).
