kaffy
- Jun 2, 2020
- 191
Good Morning fellow engineers,
I am working on a toe guard of guard rail the code requirements says
The toe guard shall be securely fastened and have a height not less than 100mm (4") above the working surface.
My question is if I run a Unistrut 1 5/8" as a toe guard and leave 2 3/8" between surface and bottom of Unistrut. I am satisfying the 4" above working surface criteria. Is it code compliant?
IS there any document clearly saying that it should be a flat plate and must touch the working surface?
