U Offor
- May 18, 2018
- 20
Hello all,
I am working on making a bottle cap for a wine glass bottle, and for the cap, it is going to be ABS polymer. On the inside of the cap, there is a cylindrical area where the top of a cork is going to sit (the cork's top is cylindrical too). However, the top of the cork is aluminum while the part of the cork that goes into the bottle (we'll call it bottom) is made from synthetic cork.
I am trying to determine the tolerance between the aluminum and ABS (when the top of the cork is inserted into the cap) in such a way that the top of the cork stays put, so one can continuously pop the cork off the bottle and place it back on without the entirety of the cork coming out.
I am thinking an interference fit will do, but what will be the effects of such a fit when using it on two different materials, in this case, aluminum vs. ABS.
Bonus: Will an interference fit work best in this case?
