pmarc
- Sep 2, 2008
- 3,169
I just need a double check on following tolerance stack calculation. What would be the minimum and maximum distance between bottom surface of the part (datum feature C) and hole surface using worst-case approach?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
