Tolerance Stacking made simple - how 1
designmr
230
The problem I've had for a bit is understanding "tolerance Stacking", anyone have a simple way to understand this?
It is adding tolerances of each parts dims tol to check for fit (max/min) into another part within an assy. One of the most important things to know in Mech Eng.
Chris
Systems Analyst
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Here is a link to a helpful document.
I would suggest doing a google on the topic
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
designmr-
For complex parts, simple tolerance stackups usually show that the part won't work when the worst-case tolerances are considered. One should introduce statistical probability. But who can put numbers to that without making some parts and measuring them? I can't count the number of times a stackup tempted me to chuck the design but all other things told me to keep it. None of those designs have come back to bite me. That doesn't mean that just because I drive over the same bridge everyday that it will never collapse!
Tunalover
Appreciate the replies. So maybe I am asking alittle too much now, but anyone show me a site where I see a small example. Seems to me easier to understand if I can actually see a small example. THANKS MUCH
Check out this site:
They make tools that help analyze stackup tolerances.
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
