Tolerance +/+ -/- 8
FeldmanWill
30
I have been using +/+ or -/- tolerances for a while now with no problems. For ex.: shaft 3" +.005/+.010, hub 3" -.005/-.010. Means shaft can be 3.005 to 3.010 and hub 2.995 to 2.990. This keeps my dimensions simple, clear and clean but tolerances drive the machining limits.
Lately somebody started questioning my sanity on this practice. Is this technique I use to GD&T standards?
William
To be fair, you should work to whatever your customer dictates. Most of ours tell us that the model rules when conflicts occur. A couple dictate that the models are reference-only and the drawing is law. The latter makes more sense, but the former is more reliable in some companies - especially those where the engineers are whipping things out very fast, to get quick turnaround on parts, and their drawings are more prone to errors than the model they invested most of their time in.
I also don't think @dgallup's comment was 'personal' or even wrong. Asymmetric tolerance zones is a basic, basic, rudimentary tool of drawing standards, going back a century. I have in my hand, right now, a copy of Machinery's Handbook published in 1919, and on page 880, there are tables titled "Allowances for Difference Classes of Fits (Newell Engineering Co.)" which shows alphabetic classes similar to our ANSI alphanumeric schemes today. The tables dictate "Standard Holes" tolerances at various diametric ranges, as well as tolerances for "Forced Fits, Driving Fits, Push Fits, Running Fits" and formulas for deriving your own.
98 years since it was published as a standard, necessary fact of manufacturing knowledge. No excuses from any relevant supplier that claims competence.
/edit/
punctuation correction
JNieman
I did not mean to point the finger at dgallup, I meant that as in general, my apologies to dgallap.
now I have worked with drawing that were designed before my time and many others here.
there was no GD&T, no standard for Gear Standards, it was what that standard was at the time.
in house standards. regardless I have to follow the print. it is the part of the contract we agreed to.
Currently there are a slew of standards we have to follow. if that is what you have to follow then it is what it is.
now if the model is considered a basic, then some where it has to be given tolerances, purchase order, an email, a contract
I think this is bad business , but it is regardless of what I think , it is what is contracted by customer and supplier.
I believe this trend to work to models is bad because I like data written down on paper. I can see programing cnc code from a model, then if it
conflicts with the drawing correct one or the other.
Concurrent Engineering is an essential part. and it is ashamed it does not happen more often.
But you are correct it is what ever customer and supplier agree to.
My points of view is what has worked for me, it may not work for others.
let me state a again maybe I was not clear, regardless of our point of view.
what ever type of tolerance is applied. suppliers, machinist , fabricators, have to hit between the tolerance , period.
if that was agreed to.
Of course manufacturing is going to try to mean center their product within the tolerance. I was merely saying there is no conflict between having a nominal dimension with unilateral tolerances and the model geometry in the middle of the tolerance zone so if it is used downstream for other purposes such as CNC programing or FEA it is representative of the desired end result. And as JNeiman stated, class of fit systems with unilateral tolerances have been around nearly as long as engineering and drawings.
I can quite easily create a drawing with the OP's shaft 3" +.005/+.010 and actual geometry at 3.0075".
Yes, but it sure is easier to modify a tolerance on a drawing if you don't have to adjust the model to do so. Also, downstream features in the part file may be inadvertently changed.
An other point from modeling is how is it verify by the inspection department? In our case we are AS9100 certified. First Article is required.full in house detail inspection plan is required.
The model size does not matter to the CMM. It will use the values it automatically pulls from the PMI value or from what the CMM programmer inputs, which includes the unilateral tolerance. It will create an upper and lower boundary for that feature, and it will measure the feature and spit out the actual value. It will never say "Hey, it's not modeled at an acceptable size" and fail a part. It doesn't care if it's modeled at 3.0000" with the acceptable range being 3.0005-3.0015".
"Of course manufacturing is going to try to mean center their product within the tolerance."
When the Gen 1 Chevy small block V8 was in it's heyday the production folks got the process to the point they could machine the decks consistently to the "high" side. The time saved, reduce tool wear, or whatever meant the number of blocks machined per day increased, and THAT was their goal.
Tmoose makes an excellent point. We constantly have a back and forth between engineering and our floor personnel on a similar topic. They tend to run our product to the stock safe side of the tolerance so that if something goes wrong, we have material left to rework them (i.e. running and outer diameter to the high side of the tolerance). This helps avoid scrap but also introduces unnecessary rework compared to us running at the mean of the tolerance.
Aidan McAllister
Metallurgical Engineer
Tmoose - That would explain why all those Chevies were so slow, with all their decks machined to the high side they were all down on compression.
A star for you dgallup! That's one my Mopar buddies haven't thought of yet.
there is more than just dimensional attributes , there is heat treat requirements, non destructive requirements, thread requirements, plating and coating requirements, some close tolerance attributes have close surface finish, shot peen, radii, milled surfaces, turned surfaces, case hardness requirements, it just depends on the products. there is a million different requirements for different parts and assemblies.
That should all be rendered moot on the manufacturing drawing. The person making the part shouldn't require knowledge of the behavior of steels during heat treatment, anodization growth of aluminum, or other such processes when making the part. Ideally, the manufacturing drawing should tell them what to manufacture the part to before the process, and call out the process to perform such that the result is satisfactory.
I can see the case for some things being left to the manufacturer when the process is very common, such as anodizing, and just calling out what the hole size should be /after/ anodizing, letting them figure out the in-between, but even that has its risks. This is what, I assume, @TheTick referred to when saying that the more specs you call out, the higher the price of the product. Instead of placing the knowledge, which you already have, and putting it on paper, you're instead requiring your suppliers or manufacturers to retrace your steps, and hoping they arrive at the same conclusion. This increases costs and can result in delivery delays while RFIs are processed. Sometimes the specs may cost money, that you're requiring them to get, which means you're either going to have to tell them over the phone/email what to do, hope they have it or they'll build that cost into the quote.
Ideally, the print has all the requirements for the part to satisfy the designer's intentions. Unless your supplier is also in some in-between "design-build" arrangement where you can rely on them to fill the gaps. In that case, you're likely dealing with a supplier who will not balk at, or misunderstand, unilateral tolerances.
At this point I'm turning to the idea that engineers should make the parts and just get rid of the machinists. That way there's no need to even spend the time making drawings in the first place. What use is the expertise of a manufacturer if their hands need to be held every step of the way, and they are likely to make the parts wrong anyway?
Fortunately this discussion is mostly about the engineering drawing, which is an entirely different thing than the manufacturing process drawing.
In most situations the engineering drawings are the manufacturing drawings, and provide the data for the CAM.
Our drawings cannot be drawn with a square corner and then have a note added for break, the exact break must be drawn. And this means that our drawings must be exactly in mid-range of dimensions (or where we want the nominal to be).
I can see calling a part '3" shaft' and the size being 3.005-3.010, but I would never use +/+ tol. Just too much chance of errors.
On your custom cold drawn shapes, is the initial draw size required on the engineering drawing? How about the original billet size? Without those, how does manufacturing proceed?
I will agree, if manufacturing doesn't pay attention to the drawing there is a good chance for errors.
Quote (mfgenggear)
Quote: That should all be rendered moot on the manufacturing drawing. The person making the part shouldn't require knowledge of the behavior of steels during heat treatment, anodization growth of aluminum, or other such processes when making the part. Ideally, the manufacturing drawing should tell them what to manufacture the part to before the process, and call out the process to perform such that the result is satisfactory. wrong every try to make gears that are case hardened. ever heard of a machine called a Gleason Quench Press, a good engineer will put down the final print requirements that's it.
a company we will call it Company A, decided to make there own Case Harden gears. now let be know it takes years of experience to do so.) they ended scraping out $13 millions of parts because they did not quite have the knowledge. and experience personnel to process parts correctly, Machine parts correctly, because of carburizing issues, gear cutting and gear grinding. because they were not trained properly.
I can see the case for some things being left to the manufacturer when the process is very common, such as anodizing, and just calling out what the hole size should be /after/ anodizing, letting them figure out the in-between, but even that has its risks. This is what, I assume, @ TheTick referred to when saying that the more specs you call out, the higher the price of the product. Instead of placing the knowledge, which you already have, and putting it on paper, you're instead requiring your suppliers or manufacturers to retrace your steps, and hoping they arrive at the same conclusion. This increases costs and can result in delivery delays while RFIs are processed. Sometimes the specs may cost money, that you're requiring them to get, which means you're either going to have to tell them over the phone/email what to do, hope they have it or they'll build that cost into the quote.
Hmmmmm OK we don't agree sorry. but after working in Aircraft, Space, and Commercial Industries. this has always been the this way.
It is a team effort between Design & stress Engineers, Manufacturing Engineers, Quality Engineers, Lead Machinist, Lead Sheet Metal Fabricators, Lead Assembly Mechanics.
Many times it was the model shop figuring how to manufacturing parts then relaying that information to the engineer. (ever heard of a master plaster) before there were computers), or Engineers designing a part that had to be built so all the errors for assembly, or static, dynamic testing had to be verified. There no one in this world that can do it all. and if they can they are a dam genius. just think of all the type of machines, and the type fabrication that has has to be done out there. space vehicles, different types of aircraft, gear boxes, and on. ( there a million people working together on these projects)
clean room procedures, plating procedures, like mention before , castings and forgings have to be fabricated, bar stock has to be made, sheet metal has to be manufactured and all of it has to meet or exceed the specification requirements. then on the engineering side there are stress and strain, loads, cycle times, can the equipment or vehicles or the ship set bird carry the loads. which is beyond the scope of the OP post. and is now hijack. sorry about that.
Many Times it the guy on floor that finds errors from print designs. and ask hey is that correct?
tolerance how you think is correct and be done with it.
