Tolerance
Tofflemire
Marine/Ocean
Oct 3, 2002
312
Hello All,
Can Proe perform a tolerance analysis in assembly mode between parts? I.E. check if 2 hole patterns on mating parts will always mate in the worst case.
Thanks for any info you can provide.
Tofflemire
Try SET-UP, DIM BOUND,
you then set up which end of the tolerance range you require. Then use ANALYSIS, Global Interference or Global Clearance.
Hope this helps.
maybe only a drafter
but the best user at this company!
