tolerancing Questions
wendert
9
I have been trying to utilize tolerancing with Inventor version 6, but I am finding it is somewhat lacking. I can tolerance my sketch dimensions in the XY, but when I go to extrude I am not allowed to tolerance the extrude dimension. Also, If I use the hole tool to create a through hole, I can't apply tolerances to the holes. Can you tolerance extrusion depth and holes via the hole tool? Or is it best to just create your holes via the sketch tools, and forget about extrusion (z) tolerances.
Can you enter the tolerance from the parameters dialog? I'm not on a machine with R6 installed so I can't check at the moment.
steven (stephen?) is right, you can do it that way. the other way to access the tolerances of those dimensions is to double a click on the feature once you've created it, which shows all the dim's on the screen like sketch dims. you can then right click any of these and select dimension properties...
AutoCol,
Where are you at? I'm here in Benalla.
Steve
G'day Steve...
I'm in Melbourne... I'm Colin, that used to work at Envision. I think we met when I came up there with the rest of the Envision crew mid-last year?
I was the young fella.
Cheers,
Col.
Running my own consulting business. Basically helping people use Inventor as well as possible.
If you know anyone that wnats specialist Inventor training or implementation work, please let me know! :)
Col.
