Too many attempts made for this increment - 3D Truss 1
DarrenDM
5
Any ideas for why I am getting this error?
I have drawn the truss in AutoCAD and imported it as a single part, assigned material/section, made the assembly, applied test loads and BCs at each end and a mesh. I am new to ABAQUS so would be great if someone could check over my project file so I can apply different load conditions.
The job input file "Job-1.inp" has been submitted for analysis.
Job Job-1: Analysis Input File Processor completed successfully.
Error in job Job-1: Too many attempts made for this increment
Job Job-1: Abaqus/Standard aborted due to errors.
Error in job Job-1: Abaqus/Standard Analysis exited with an error - Please see the message file for possible error messages if the file exists.
Job Job-1 aborted due to errors.
 http://files.engineering.com/getfile.aspx?folder=ae2b26cc-1f93-4ae0-b86c-97801b18e9f8&file=run1.cae
Change the step to linear perturbation static and you'll get a result. It looks like you have a lot of buckling. Check your unit system and all input data.
