As an automotive technician, and NOT an engineer, nor someone with even the slightest ability to draw I often have ideas for a tool to make my job easier but no way to create them. Frankly I don't really care much about the process required for patenting etc. anyway so tell you what. Here's what I want, someone make it!
Air Chiesls (hammers) have been around for a while. But there is one specific use that they would be great for, but the repeating nature of the tool defeats any real chance of doing so because you cannot control it once it starts hammering. The use would be to install freeze plugs in the side of the engine block, which often means the tool would have to operate at an angle. It also must be able to hammer in single shots per trigger pull for precise control. One added advantage would be if the hammer strength could be adjusted as well from a slight tap, to the equivelent of a full arm swing with a 20oz hammer. When confined by clearances, many times a technician cannot get any room to swing a hammer, but a properlly built tool would not need the space that a regular hammer would. As far as the "angle" portion of the tool goes, I have some ideas but they would need drawn and tested for practicality as well as durability.
OK There it is, You build it, you can claim it. But someone build it for me!!!!
There are more ideas from where that one comes (VBG)....
