SperlingPE
I have a situation where the truss does not coincide with a stud. The truss bears midway between two studs. There is a double top plate. The wood species is SPF no. 2 or btr. The additional stud interferes with insulation. Is there any way that this works? Can the load be assumed to transfer into the plywood sheathing (sheathing will be present prior to truss erection) to account for some extra capacity?
