Top reinforcement in slabs - Minimum Rebar
NAFTALI-HAKOHEN
26
Im looking for a clear reference to minimum rebar requirements, in the upper layer of a large span , that has only sagging moments in the centre of the span, ie there is no structural purpose for this rebar.
(i see that 50% of steel required for sagging moments must extend to external supports, but i dont see a minimum for hogging steel being continued to middle of span)
Naftali
You need to include a code or specification, and the section you're referencing for the requirements.
