Torque Calculatons During Constant Load
ddelaiarro
I have the following set-up:
A brushless motor (w/gearhead) is attached to a pinion. The pinon is mated with a gear (they are normal spur gears). The gear is attached to a shaft with a 20-lb disk (pallet) on top of it that spins at a constant velocity.
The pallet goes through the following cycles:
- accelerates from 0rpm to 30 rpm in 5s
- runs at a speed of 30 rpm for 10min
- decelerates from 30rpm to 0rpm in 5s
- sits idle for 5min
- repeat process 24 hrs/day, 365 days/yr
The uptime on this tool is estimated at 85%. I know the torque that is needed to initiate rotation based on mass moment of interia of the moving parts and drag torques provided by such things as a ferrofluidic feedthrough, water union, etc.
I'm trying to figure out some durability/lifetime information for the gears based on a minimum of a two year life. What I really need to know is the torque required from the motor during the continuous stage (30rpm for 10min). As I mentioned, I know the torque during accel/decel, but the continuous stage is a big tricky.
Any help anyone can lend would be most appreciated.
I assume you can measure the current that
is drawn during the 10 minute cycle to give
you some idea of the torque that is required.
This system is not physical yet, it's still in the developmental stage. I'm working on designing a gear set that will not fail once we've manufactured the system.
Dumb question but can you balance the shaft
by adding a counterwieght opposite the pallet?
Going to be hard on the motor bearings as
designed with that much excentricity.
I'm not sure I understand what you mean? The shaft is in the vertical position with the pallet (a roughly 12" diameter, 2" thick disk) on top of it. The whole assembly looks like a large T.
OK, different story. I assumed a horizontal shaft.
Yeah, I suppose I wasn't very clear on that fact. I forget that people haven't been staring at it as long as I have.
