marktheyeti
I'm dealing with what appears to be a torque sensor malfunction that I have not seen before. Using a rotary torque sensor to measure applied load to a rotating shaft (180 rpm), I have recorded a very consistent, gradual increase in the measured value over a period of several days. I know, due to other measurements in the system, that this is not a changing condition of the applied torque, but rather a malfunction in the rotary torque sensor. I'm hoping that someone else here has experienced this type of sensor failure or knows what might be causing this consistent signal drift. The measured equipment is known to be in steady-state condition, and measurements at other points in the system indicate that the actual applied loading cannot be changing in the way the torque sensor indicates.
This is a wheatstone bridge-type rotary torque sensor with four brushes contacting slip rings to transmit the signal from the rotating shaft to the non-rotating housing and signal wire connector. The slip rings and brushes appear to be in good shape, with no visible damage and a significant amount of brush life left.
Any help of advice is appreciated.
Mark
Mark
