Torque wrench Calibration: Required date as per which code.?? 1
steakman911
Petroleum
CA
Howdy.
Working with B31.3 piping as well as fired and unfired boilers/vessels/exchangers on a SAGD site in N. Alberta
Can someone please direct me to where in the ASME codes is the stated interval for calibration.? I have always considered the maximum time between claibrations is 1 or sooner depending up service...just like to know where that is stated.
Thank you,
Stk
What does your approved quality system require?
Plymouth Tube
Having just re-read the entire section of our QMS pertaining to Inspection / Measuring & Test Equipment. No specified time schedule is noted. Only that this must be done at a "specified frequency". However said frequency is not in fact specified.
Im fully aware and have always used a yearly frequency unless a TQ wrench has become damaged or is suspected to be out of calibration. I was simply curious if this was an item that might be required by either Sect V, B31 series or API for that matter.
Stk
Not addressed in B31.3. Try ASME PCC-1.
Thank you..I shall do exactly thaT.!
cHEERS,
sTK
