torsion analysis required? 6
Lman321
5
Please refer to the attached roof framing plan.
W9x9 cantilevered 8'-0" from column line L. They are fully welded to W24x55. W12x14 are provided for lateral buckling.
I'm trying to avoid a complicated torsional analysis on the W24x55 along L. Is this possible?
Please advise.
BA nailed it long ago. Why not use a W18 instead of a W24 and cantilever the W6s over the top?
Would it work as a composite beam with the W6 going across it? Just a thought.
hokie,
Just a brainstorming suggestion that adding concrete in this region may increase the options (even if unconventional)
Lman321,
I think the way to solve this is more financial and architectural than engineering. Give them a scheme that will work exactly how they have designed it no matter how expensive.
Then give them a scheme that is an architectural compromise such as diagonal braces, deeper canopy, or better still a canopy that is deeper toward the building but has the same edge.
Encourage them to get the options priced up.
You will then get to implement your 'compromise'.
I try to never say no to a client, instead I will say that the best I can do is this, this or this and let them make the decision.
csd,
Nothing against brainstorming, but I thought this was just a roof with metal deck, and hadn't thought of concrete as a practical part of the solution.
