whatif
- Aug 11, 2000
- 2
I’m currently working on a design for a mount that holds a torsion bar spring from turning. The torsion bar has ends that are hexagonal in shape similar to a regular hex head bolt. I’m running into trouble trying to calculate how much surface area I should have in relation to the torque that will be applied to the spring, also the thickness of material at the corners.
Any ideas on how to calculate the size of the hex end?
Darryl
Darryl
