DownHillHero
I'm trying utilize a torsion bar to support a load as well as facilitate a flipping motion. A similar set up of this can be seen in a product known as a flippac and to start I was trying to figure out how the torsion bar in the flippac is able to support so much load.
The dimensions of the supported section of the flippac are about 80"x64".
I believe the torsion bar is made out of some kind of 4140 steel that has been heat treated and oil quenched. The shear modulus G=11600 ksi and yield tensile is 251600 psi. Since we will be dealing with shear stress, the shear yield is about 50% of the tensile, so 125800 psi. I have incorporated a safety factor of 1.5 giving an allowable shear stress of 83867 psi.
Here are the dimensions and constants I have been using to determine the torque in the torsion bar.
Torsion bar length = 54"
So far I have been using the formula
phi = (T*L)/(J*G)
where phi = angle of twist (rad)
T = torque (in*lb)
L = length of bar (54 in)
J = (pi/2)*r^4 (in^4)
G = 11600 ksi
At the point of interest, the load is about 500 lb which is acting 40" away from the hinging point. This results in a moment of 20000 in*lb, therefore the torque in the torsion bar must be 20000 in*lb to support the weight (the flippac has two support beams in the front, however 95% of the load for two people, about 400 lb plus the weight of the lid is supported only by the torsion bar). The angle of twist in the torsion bar at this point is 90 degrees = 1.57079 rad.
Using the equation above we can find the require radius of the torsion bar to allow for this motion to happen. From my calculation I'm getting r = 0.4407"
Next I used the formula t_max = (T*r)/J to find the maximum shear (t = shear). In this case the maximum shear is 148718 psi.... well above the yielding shear strength of 83867 psi.
Does anyone have any ideas on how flippac does it??? I am stumped.
phi = (T*L)/(J*G)
T = torque (in*lb)
G = 11600 ksi
