Hi guys,
i am dealing with big beam dimensions where the minimum torsion longitudinal reinforcement is coming too much and exceeding the Al required for torsion. (the beams width are ranging from 1.5 to 2m and depth around 1m).
according to ACI, torsion longitudinal reinforcement should be equally distributed to the 4 faces of the beam. This is also applied to the minimum longitudinal As.
I am wondering if this reinforcement(which is minimum) can't be calculated using benefit of the total reinforcement located at the bottom which is unstressed. for example, assume that the minimum As (minimum required for torsion) is 96cm2 and the bottom reinforcement as support (or d away from support) is 56cm2. cant i deduct (96-56)cm2 and divide the remaining As by 3 faces ??
Thank u
Thank u
