metootoo
- Aug 9, 2007
- 21
We had the output shaft of a torque wrench fail. The torque wrench is rated for 3200 ftlbs. The square output shaft is practically 1.08 inches square. According to the formula I used [ Max Torque = (2/9)x shear stress x(width of square)^3, where shear is .42*yield], the shaft would have to be made of 417ksi material. Hardness testing a new shaft resulted in HRC between 42-46 on the outside, suggesting a yield of around 217ksi at best.
I'm I looking at this wrong, or is the torque wrench over-rated? We found the same problem with another top brand as well.
