formula94lt1
Automotive
The equation I found for this is assuming the use of mild steel and is as follows.
R= (5x10^6 x D^4)/(.4244LA^2 +.2264B^3)
D=diameter
A=effective lever arm length
B=lever arm length (same as above no? unless arm is at an angle)
L=length of bar or tube or whatever
R=roll bar rate
Now I am curious if anyone else is familiar with this equation and if it is in Ib/ft per degree or what?
D=diameter
R=roll bar rate
