romulus102
- Nov 10, 2016
- 3
The CMM section in my workplace are measuring total runout on a bearing seating surface. The way it was explained to me is that they take scans axially along the surface,construct a cylinder and calculate the total runout. I am struggling to understand how this calculation exactly works.The confusion is arisen from the fact that I was always shown total runout being measured at 3 locations i.e. a DTI placed on the part, part rotated, next axial position checked and the maximum of the 3 readings was the total runout. On reviewing, Fundamentals of Geometric Dimensioning and Tolerancing by Alex Krulikowski, this book states that total runout needs to measured in a manner such that the DTI follows a helical path.
Based on the above description,I would appreciate any advise on the two questions below.
1:what is correct method to measure total runout as per ASME 14.5.
2:How does a CMM(LK Machine with a Renishaw retrofit, using Modus software) actually calculate total runout.
