HofOblivion
- Dec 15, 2014
- 13
A fellow engineer told me that you could design wood shear walls using the total shear design method. Every shear walls designed with equal unit shears based on the story shear.
I always thought that wood shear walls need to be designed with a tributary method based on the flexible diaphragm method.
Has anyone used total shear design method? And if so, which code section allows this design approach?
