Lomarandil
- Jun 10, 2014
- 1,926
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
A crane’s vertical mast is composed of 20-foot sections that are generally removed by another crane, two at a time because a tractor-trailer can carry a 40-foot load.
“It’s just a matter of unbolting the tower sections and lifting them down,” Ritchie said. “Some people like to remove the bolts ahead of time.”
The sections are bolted together, usually with two or four bolts or pins at each of four corners. Sometimes, Ritchie said, crews will remove most of the bolts from multiple sections at the same time, leaving only two bolts, at diagonal corners, connecting each section.
