bigpaul
Automotive
- Apr 25, 2003
- 27
Hi help needed with a run of bearing problems on Toyota 4 age engines, we build a high number of these engines without
problem but we are currently haveing a nightmare with Connecting rod bearings what we have is bearings which show classic fatigue problems but do not have a trail to explain the fatigue
we have used diffrent running clearances lubrication
oil pressure and flow also alternative bearing material
and manufacture even lowering compresion this is over
several engines any help or ideas will be gratefully recived
these failures occur in less than 200 miles.
Big Paul.
Big Paul.
