Hi Is there any way to add trailing dimensions with out inserting them manualy.
For example 80.00 instead of 80 which I seem to be getting.
Is there a switch in the settings?
Shouldn't this be accomplished by setting the precision of the dimensions? Try going to Tools, Options, Document Properties tab, Units and then set the number of Decimal Places to 2.
none of the above seem to work. Changing the precision to 2 will imput 80.01 if that is the size but for 80.00 it imputs 80. i am working in Ansi settings have tried ISO with the same results
What units are you using? If you are using metric units, you won't get trailing zeros. If you use inches, you should see them. "The attempt and not the deed confounds us."
I tried that with feet and inches - if it is an even number of feet, the inches don't show. "Show" doesn't seem to help in ANSI or ISO. I tried changing the precision too.
