amitkumarnain
- Aug 6, 2014
- 2
I need to transfer motor once it reaches 50Hz i.e 100% speed on vfd to mains .The same needs to carried out for FC102 , ACS850 , ACS550 , ACS800 . I hear the synchronous transfer option exists for ACS800 . Danfoss has agreed to offer synchronous card (which is still in R&D ) .My going through various forums here and others i understand following solution exists :
1.) Use Synchronous transfer cards. But these are available only for Danfoss FC102 and ACS800 . What do i do about ACS550 / ACS850 loads?
2.) I can ramp up the motor to say 52.5Hz instead of 50Hz and bring vfd out of loop , use phase sensing relay . When this relay senses phase angle from back emf being generated by motor is same as mains power supply switch on the bypass contactor .
I see option 2 is more like hit and miss .
Also what will happen if i just bring vfd out of circuit and switch on DOL without any sensing of phase or use any Sync cards.
For ACS800 Sync Card is RSYC-01 . Can this or any other card be used for ACS850/550?
Thnks
Akn
Thnks
Akn
