Transfering Document templates 1
arb65912
20
I have a part document template I want to apply to a new part
that was not created with the template above....
Anybody can give me a hint on how to "transfer" part template into new part?
Thank you.
Andrzej
Thank you very much Limey.
That's exactly what I need :)
Andrzej
Oops! .... I was assuming my problem was solved.
mac_copydoc.zip is a Excell spreadsheet and I do not know how to run it, sorry.
The other macro I found works only on drawing templates ....
Andrzej
Open the Excel file, click on the Description tab and read the Short explanation details.
[cheers]
My apologies to you. That Excel file also only works on drawings apparently. I thought that was the one which worked on alldoc' types. I will have to dig deeper.
[cheers]
I just checked , as you said, it does not work on drawings.
Please let me know if you find anything that would do that.
I have some custom set properties set in the part template like
Part Name, Material Usage that has to be edited manually later on and few others.
All I need is to copy the settings from the template to show in the copied part .... sounds simple, doesn't it :)
Thank you , I will try it over the weekend and let you know how it worked.
Andrzej
My macro actually have a method for you to do this:
You'll need to mod the code to apply to your custom properties, then use the copy properties function when you run it. This is the only macro I know that copies custom properties from one doc to another on-the-fly.
Also, has a macro that can copy properties from one file to another, even in a batch process.
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
sw.fcsuper.com
Co-moderator of Solidworks Yahoo! Group
Matt ... I don't believe arb65912 needs to copy the Custom or Config' Specific Properties. He's wanting to copy the Document Properties and/or System Options as available from the Tools > Options section. ie. the document template settings rather than the component properties.
[cheers]
I was just going by "Part name". Normally this is a property and not a setting. Material can be a setting, but it also often a property instead.
Matt
Silicon Valley, CA
sw.fcsuper.com
Oh Geez, I completley missed that post. In that case I don't know what is wanted, where it is or who's on first. [lol]
If they are straightforward custom or config props, they should be copied over when the template or component is copied. Unless some strange copying procedure has been used.
[cheers]
I am sorry guys, maybe my description of the problem was not clear....
OK, I have a part template let's call it GoodTemplate which has some Configurations specific and Custom properties set in it.
I created partB which is a copy of part A.
Part A was created using some template that I do not care about.
I want part B to have Configuration Specific and Custom Properties same as GoodTemplate.
I hope I described it better what I am looking for.
Sorry for the confusion again.
Andrzej
Thank you Limey,
I will check this out ASAP and I will let you know how it went.
Andrzej
CorBlimeyLimey,
It did work.
Thank you again.
Andrzej
