kjell123898
We have performed a PQR of a 45mm plate in S355 material and weld position 3G. Welding method is FCAW. The number of single welding layer is 50 pcs achieved during the PQR welding.
Please may someone state which of the calculation methods are most appropriate when observed heat input values to be transferred to the applicable WPS.
Question: Shall we use an average heat input value based on all 50 passes (+/- 10% min/max range)? or shall be rather use the minimum and maximum heat input value from the single pass to determine the heat input range in the WPS?
This matter is the subject of extensive discussions and I feel it will be like that one strives for a wps with greater validity than technical advisable....
Kjell Gr°nvold
Kjell Gr°nvold
