Transferring image to surfaces
markwindsurf
Automotive
Nov 2, 2009
24
I have been asked by a customer to add their logo to a panel is their some format of graphics file that I can use which will provide an edge curve so that I can use these to create the surface without having to redraw?
Thanks.
this is a good way to use picture as a texture. used that several times[pc2].
if a logo not too complex you can convert it to dxf and then workaround with that.
Thanks for your comments. Unfortunately the logo is a very complex flowery script, so impractical to trace. JeniaL how would I translate the image to a DXF?
could you ask the client to give you vector file logo ?
Eric N.
google for scan2cad they have a trial. with a complex picture converting won't help.. post a logo i'll try to help
