daveparkinson
Afternoon all,
I want to create, set up and trial a vault on my laptop and then transfer it to my work server once I am happy with it.
My reasons are...
1) More time to trial the vault.
2) I can't seem to get 5 minutes to myself in the office.
I am the only person using the vault, as I am the only Solid Works user. Are there any best practices that I should follow when transferring a vault?
Finally, how do you transfer a vault? Is it a case of overwriting the unwanted Vault Data folder with the correct Vault Data folder. Or should I be using PDMW Export?
Do I have to manually make sure that all of the Lifecycle/Revision options in VaultAdmin are identical, or can I choose to copy the settings over (from the laptop version)?
Cheers
My reasons are...
Cheers
