Where does the Eddy current induced in transformer core laminations? Means in which area, suppose rectangle lamination with length L ,width W and thickness X,? and why? And what's the angle between main magnetic field and the core laminations is it parallel to it or Perpendicular ، then how it cut the laminations to induce Eddy current? and does the insulated surface is subjected to induced Eddy current also?
